Hello
i am burying a PIR cable along the top of the wall, but there are cables from the light switch, will it be ok to run these close ?dont have any option really, but wonder if it could cause false alarms, there won’t be any power flowing at night or when out...but will obviously be live.
thanks
If your going by the regs:-
50mm separation between all ELV and LV cabling. "Additional insulation should be provided" if they need to cross over each other, preferably perpendicular to minimise any interference.
Seems a fair bit of mess for one alarm cable? Would have looked at going upwards or if really required a thin chase into the cove, disappears with cork.
Just now, sixwheeledbeast said:
Seems a fair bit of mess for one alarm cable? .
Looking at the picture, he must have a very understanding wife or lives alone....
  • Upvote 2
2 hours ago, Reddwarf4ever said:
Hello
thanks
As said above , what's above ? Carpet?
Cables look so close to the surface doesn't look as if you will get.much filler on top either
Other option break more plaster below and go behind them a little , is it an outside wall ? Or internal , old internal breeze block?
Although messing with the coving is an option you get it wrong it will be messy and always noticeable
He will strip them back to the indivual cores first silly
Ah so you mean strip of jacket of cable
Flatten cores out and use Wickes 60min silicon to form into a ribbon cable spot
Nsí tricks are so cool .....
Not possible I am afraid, the alarm cable ,is 6 core Think only two,used for the PIR and it is the highest quality I could get so screening should be good.......suppose it’s fingers crossed than ?
