Ian 1 Posted August 5, 2020 Posted August 5, 2020 I’ve lost the code for the alarm, now I’ve had a power outage the alarm keeps going off how can I do a factory reset and change my code. Cheers Quote
sixwheeledbeast Posted August 5, 2020 Posted August 5, 2020 As per our guidelines we don't provide that information here. i can only suggest you try codes you may think it could be. If the system is misbehaving due to a power outage then something is wrong with it and it's in need of a service visit, they will be able to reset the code for you at the same time. 1 Quote
