Guest aechlin Posted November 26, 2004 Posted November 26, 2004 Hi guys I have the TS790+ and was wondering where in the Installation manual there could be reference to pulse the strobe on setting/final exiting of the system, is there a programmable output I can use? Would I get anywhere if I used the custom outputs? Best Regards Alistair
Guest Posted November 26, 2004 Posted November 26, 2004 Programme one of the panel outputs (1 to 4 - output 1 is the relay output, output 2 is switched negative at 500ma) - to 075 using eng menu 1.1 this will confirm set strobe for a few seconds on full system set and also continue to strobe for any alarm conditions. (You will have to link in the -ve strobe feed that goes to the bellbox to the output you choose, and if you choose the relay output no1 youll need to give the relay a negative common first) If your not an engineer We cant give more specific instructions or any manuals sorry - unless your registered as trade, and also this is not a job for a DIY'er unless your in the trade as you could pop the panel and or yourself.
CompostCORNER Posted November 27, 2004 Posted November 27, 2004 You should be able to program an output as a 'customable' output. This means you can program more than 1 rule for the output. If I remember correctly, the rules can be as a set of 3 AND's or 3 OR's. An example of each:-- ANDs... You can program the output to fire when.... 1 Part Set A 2 Part Set B 3 Part Set C This means the output will only fire when ALL those 3 events take place. ORs... You can program the output to fire when.... 1 Part Set A 2 Part Set B 3 Part Set C The same rules have been programmed in but the output will fire if any 1 of the 3 events take place. I think you can mix and match too to create truly custom outputs. Been a while since I've programmed a custom output on a TS790 but it is straight forwards. Obviously, you replace the 3 rules (Part Set A, B and C ect..), for any of the standard output rules.
Guest aechlin Posted December 2, 2004 Posted December 2, 2004 Thank you DNS, I have done what you said and shes working fine. Thank you Alistair
Lectrician Posted December 3, 2004 Posted December 3, 2004 Will this 075 work on TS690 aswell?? My TS790+ and TS690 manuals do not have a 075 listed on the programmable outputs !?! Email : martin@askthetrades.co.uk
Guest IM_Alarms Posted December 3, 2004 Posted December 3, 2004 It is 048 on a TS690, in the programmable outputs section. This will flash strobe on set
Guest Posted December 3, 2004 Posted December 3, 2004 It is 048 on a TS690, in the programmable outputs section.This will flash strobe on set 33634[/snapback] Yes this is true but only on the later panel versions - the early 690's didnt have the option, they only introduced 048 on later ones.
