lesallen45 Posted September 14, 2020 Posted September 14, 2020 I am trying to change a PIR into my Scantronic 500r system but all instructions are not working. Can anyone help. I have tried putting in my access code then 81 for programming mode nothing, then 82 for removal of a programmed area & still nothing. Any help would be gratefully appreciated.. Quote
james.wilson Posted September 14, 2020 Posted September 14, 2020 definitely entering the correct engineer code? Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
lesallen45 Posted September 14, 2020 Author Posted September 14, 2020 (edited) Thank you, What I have read in the installation manual is ####. I have entered my user code & then ####. Tried user code plus 81 for programming. I am at a loss now. Obviously something is wrong.. Edited September 14, 2020 by sixwheeledbeast No codes please Quote
sixwheeledbeast Posted September 14, 2020 Posted September 14, 2020 It's likely not the code in the manual you would normally change it. Quote
lesallen45 Posted September 14, 2020 Author Posted September 14, 2020 So if that is not the engineer code it could have been changed by the installer would that be correct? Any other way to change the programming? Quote
MrHappy Posted September 14, 2020 Posted September 14, 2020 3 hours ago, lesallen45 said: Can anyone help. I have tried putting in my access code then 81 for programming mode nothing, then 82 for removal of a programmed area & still nothing. Any help would be gratefully appreciated.. 0 then eng code 0 Ent then eng code If you don't have the eng code, the book has defaulting instructions However the 500r is old tat, personally I'd kick it off the wall... Quote Mr Veritas God
james.wilson Posted September 14, 2020 Posted September 14, 2020 It's normal practice to change codes from default Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
lesallen45 Posted September 15, 2020 Author Posted September 15, 2020 Hi Mr Happy, thanks for your input have changed the insides & it works. Regards "old Tat" just because it's old if it is still serviceable you don't kick it off the wall. Obviously if you are a supplier you would recommend a new system but I paid GBP13.00 for the PIR. How much would a similar system be today to replace this one with 4 areas/ PIR'S. Quote
sixwheeledbeast Posted September 15, 2020 Posted September 15, 2020 I am all for if it's well maintained and serviceable then look after it and it will serve you well. You have to consider with old wireless systems that it's mostly one way an not considered reliable or secure any more. With one way systems it's possible for the panel not to receive a message send from a PIR (therefore you have no alarm), the panel has no way of sending messages to sensors to make sure they are operational. A bit like you don't see WEP being used for WiFi any more, in it's day it was considered fine. Now most are aware connections can be compromised in minutes and more modern protocols are in use. Quote
MrHappy Posted September 15, 2020 Posted September 15, 2020 2 hours ago, lesallen45 said: "old Tat" just because it's old if it is still serviceable you don't kick it off the wall. Can I get new parts for your product from a reputable source ? 2 hours ago, lesallen45 said: but I paid GBP13.00 for the PIR. you was robbed.... 2 hours ago, lesallen45 said: How much would a similar system be today to replace this one with 4 areas/ PIR'S. If your fully comp £0 if your paying for new £600 ish ? 1 Quote Mr Veritas God
