paulbaker1954 Posted September 29, 2020 Author Posted September 29, 2020 Now it’s pissing memoff Peogrammed sensors to off in main panel (program zone types) and still triggers a tamper alarm frequently Tried taking battery out and this triggers another error code with an “L” after it when trying to set the alarm. Any ideas please Quote
MrHappy Posted September 29, 2020 Posted September 29, 2020 "L" means lost, "delete the circuit off " aka remove the transmitter in the zex menu 91-98 or whatever +no ? Quote Mr Veritas God
paulbaker1954 Posted September 29, 2020 Author Posted September 29, 2020 8 hours ago, MrHappy said: "L" means lost, "delete the circuit off " aka remove the transmitter in the zex menu 91-98 or whatever +no ? Hi and thanks for the reply but I am still a bit confused. I have the programming manual for the panel but can’t find the program option to remove the transmitter . You refer to the zex menu but not exactly sure what you mean . Soory to be dim but am not super familiar with this setup Quote
al-yeti Posted September 29, 2020 Posted September 29, 2020 29 minutes ago, paulbaker1954 said: Hi and thanks for the reply but I am still a bit confused. I have the programming manual for the panel but can’t find the program option to remove the transmitter . You refer to the zex menu but not exactly sure what you mean . Soory to be dim but am not super familiar with this setup You using right access code? Quote
Hillbilly Posted September 29, 2020 Posted September 29, 2020 You need to enter eng code then user code.... scroll to Zones....enter 50 Yes and work your to disable wireless zones etc. Quote
paulbaker1954 Posted September 30, 2020 Author Posted September 30, 2020 19 hours ago, Hillbilly said: You need to enter eng code then user code.... scroll to Zones....enter 50 Yes and work your to disable wireless zones etc. Sorry there ain’t no zone 50 it’s a gardtec panel with a a separate wireless box wired in to the main panel Quote
al-yeti Posted September 30, 2020 Posted September 30, 2020 2 hours ago, paulbaker1954 said: Sorry there ain’t no zone 50 it’s a gardtec panel with a a separate wireless box wired in to the main panel You menu menu 50? Quote
paulbaker1954 Posted September 30, 2020 Author Posted September 30, 2020 29 minutes ago, al-yeti said: You menu menu 50? Menu 50 is zone wiring (EOL) etc Quote
paulbaker1954 Posted October 1, 2020 Author Posted October 1, 2020 23 hours ago, paulbaker1954 said: Menu 50 is zone wiring (EOL) etc Thanks all got it figured out now Quote
Hillbilly Posted October 2, 2020 Posted October 2, 2020 I meant when it says programme zones go 50 yes. Quote
