texecom azura 360 tempest
Guest ron
brand new to alarm systems
bloke in shop sold me
external sounder & stobe unit
plus
Accenta/Optima G3
8sp 400n intruder alarm system
only -ve strobe connection on bell box
but on manual of control panel it shows + and - strobe connections
am i missing something or are these units not compatable :!:
Quite a few Bellboxes only use the Negative strobe connection, they get the positive from the bell hold +.
thanks for reply
so does that mean i connect the spare wire(white) in the bell box along side the + ve supply red wire.
Then in the control panel the white will go to the +ve strobe
Not spark as you can tell
No it means it doesnt need connecting to the bellbox at all.
The 6 terminals in the panel are there to accomodate any bellbox, some boxes require 4 wires, some 5, and some need all six.
32992[/snapback]
ta will fix it tomorrow
it is a bit dark outside at the moment and i am a bit tired
