inglishg Posted October 11, 2020 Posted October 11, 2020 I not particularly expert on computers and the Internet, so a question from one guy leaves me in the position where I need to ask you experts... A customer has a cctv system using the (dare i say it) xmeye software. However, despite the system apparently having a good Internet connection (via mains booster sockets, rather than hard wired ethernet cable), he cannot get access on his phone when he scans the serial number QR code. He has said he uses a VPN to hide his location as he has some remote TV access via a fire stick. Is this the reason for his trouble, and should he do something different? Thanks in advance for your help! Quote
sixwheeledbeast Posted October 11, 2020 Posted October 11, 2020 Possibly. Depends how the network is setup and the provider. Do all connections definitely go via the VPN? If he's been able to set his network up to route most traffic via a VPN, I would expect he would be capable of setting the cameras to not use it? Quote
al-yeti Posted October 11, 2020 Posted October 11, 2020 40 minutes ago, inglishg said: I not particularly expert on computers and the Internet, so a question from one guy leaves me in the position where I need to ask you experts... A customer has a cctv system using the (dare i say it) xmeye software. However, despite the system apparently having a good Internet connection (via mains booster sockets, rather than hard wired ethernet cable), he cannot get access on his phone when he scans the serial number QR code. He has said he uses a VPN to hide his location as he has some remote TV access via a fire stick. Is this the reason for his trouble, and should he do something different? Thanks in advance for your help! Is he on O2 or ee? Quote
inglishg Posted October 12, 2020 Author Posted October 12, 2020 8 hours ago, al-yeti said: Is he on O2 or ee? I understand he is using a hard wired Sky broadband but uses a VPN to protect his firestick viewing. Quote
inglishg Posted October 12, 2020 Author Posted October 12, 2020 8 hours ago, sixwheeledbeast said: Possibly. Depends how the network is setup and the provider. Do all connections definitely go via the VPN? If he's been able to set his network up to route most traffic via a VPN, I would expect he would be capable of setting the cameras to not use it? I don't know who set up his VPN, or how it is configured. In truth I know nowt about them! I'll call to see him when I'm in his area later this week and try to gain more info. Thanks for the help you've been able to give again. Quote
al-yeti Posted October 12, 2020 Posted October 12, 2020 12 minutes ago, inglishg said: I don't know who set up his VPN, or how it is configured. In truth I know nowt about them! I'll call to see him when I'm in his area later this week and try to gain more info. Thanks for the help you've been able to give again. Cool tell him to hire IT man , I assume everything works without VPN Quote
inglishg Posted October 12, 2020 Author Posted October 12, 2020 19 minutes ago, al-yeti said: Cool tell him to hire IT man , I assume everything works without VPN He's had his VPN for a while - he was quick to demonstrate the vast access to literally thousands of TV channels, but needs to "hide" behind a VPN (probably makes more sense to you than me...I just have freeview which gives me what I need!) However his cctv is new and he's not been able to get it running despite showing an Internet connection...and thought I may be able to help. I said not me, but suggested I may be able to find someone who can! Thanks again for any pointers you can give. Quote
sixwheeledbeast Posted October 12, 2020 Posted October 12, 2020 (edited) To try and give you some idea it's not specifically "a VPN" that would cause an issue. VPN is a bit of a sales buzzword at the moment and used for all sorts of services and marketing rubbish. In a simple form they are just a way of tunnelling your traffic via an "encrypted pipe" to another location anywhere on the internet, you can have private ones to link remote sites as if they are on the same network for example. "VPN services" you see advertised are generally sold to pipe as many connections as possible so there connections look like they are in another country this would be to access geolocation blocked media. You wouldn't expect to get all services through these due to NAT and the way the traffic is routed, certainly hosting services would be an issue like with CGNAT. To try put it simply you need to know where this "pipe" starts (I am assuming the router in this case?) and not route the CCTV via it if possible. Edited October 12, 2020 by sixwheeledbeast typo 1 Quote
inglishg Posted October 12, 2020 Author Posted October 12, 2020 This is very helpful - thanks. I'm sure the guy knows more about all this Internet stuff, so he should be well placed now. I do so much appreciate you helping like this. Quote
al-yeti Posted October 12, 2020 Posted October 12, 2020 4 hours ago, inglishg said: He's had his VPN for a while - he was quick to demonstrate the vast access to literally thousands of TV channels, but needs to "hide" behind a VPN (probably makes more sense to you than me...I just have freeview which gives me what I need!) However his cctv is new and he's not been able to get it running despite showing an Internet connection...and thought I may be able to help. I said not me, but suggested I may be able to find someone who can! Thanks again for any pointers you can give. You mean he's teefing TV channels so trying to hide behind VPN , funny thing is , if authorities were after every small timer he would easily get caught , VPN don't hide you completely.... Quote
