Good evening.
I hope there is a kind soul out there that could help me with the installation of my system.
I just bought my system from the Swedish security company Securitas G4S, and moved it from my old shop to install it at home.
Sadly I only had 2h to take the system down and did not mark the cables up before taking it down...
I was wondering if there is anyone out there that could help me with the instructions of installing this system in my home or at least give my pointers as to where all the wires should go.
What I have is:
1x Main unit Honeywell SD8100 (looks just like your English Galaxy Flex 50),
1x keypad
1x Cam (Axis i this its called)
1x Rio C078
4x Door magnets,
6-7 PIR
1x smoke detector
2x alarm sirens/ bells (indoor)
If its helpful I could take som pics on how it looks today (with the EOL resistors and all)
All parts are marked up by Securitas with 4 digit numbers.
I really hope someone can help me with this.
Thanks in advance,
Henrik (from Sweden)
Assuming its a flex then you should be able to wire it up. Id suggest you head over to the DIY area and make a post for each bit that your doing, ie data for keypads and expanders. Title it accordingly.
If you post with 'ive got all this gear how do i make it work' few people will respond as the reply would be huge!
Posted (edited)
Many thank.
I'll try to do that.
Would i need to reprogram the main board or GSM board?
For the unit not to call the old phone number to Securitas and instad call my mobile phone alt not call any numbers at all and if so, what program should I use?
Edited by Henrik
