22 minutes ago, al-yeti said:
But we already told you where to start?
Are you basically saying you don't have a clue how to find the manual to atleast wire the keypad to the control panel
If you can't get that bit done , I would forget Bout this .....
Not at all, I’ll get it done.
thanks for all the good advices.
All I thought was since all you guys are obviously knowing what you doing with in low voltage security system you could give me some heads up in regards to the difference EOL resistors that’s already fitted to the system since it’s been installed ones before and I guessed the way of installing this system was pretty much the same all over the world since you all use the same numbers and markings.
Im not a alarm system installer but if this was something that i knew I would sort of recognise the setup from what I saw in the pictures, just saying.
But I’ll start all over again and figure it out.
Have a great weekend everyone and stay safe in this Corona times.
If you want to be a DIY alarm man, put the controls on bench, link anything out & default it
Once you have control of it & can get it fault free into day
start adding detection circuits  & learn how it works then try fitting it on the wall
3 hours ago, Henrik said:
Did you not read the posting???
This is UK , we don't read anything , especially manuals until we desperate
Its why I said shorten the posts down, we get bored after the second sentence, one question at a time, you will get more sensible replies
Ok guys, got everything up and running just fine.
i do however have an slight issue.
when I took the alarm down I most have missed one PIR hanging on the wall (address 1002).
how do I go about entering the engineer code to be able to delete the address 1002?
And is the engineering code always the same or is it changeable by the company who first installed the system in my old shop?
thanks in advance,
Henrik.
