james.wilson Posted October 28, 2020 Posted October 28, 2020 it should be changed for security reasons Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
Imnotshankled Posted October 28, 2020 Posted October 28, 2020 (edited) 55 minutes ago, Henrik said: Ok guys, got everything up and running just fine. i do however have an slight issue. when I took the alarm down I most have missed one PIR hanging on the wall (address 1002). how do I go about entering the engineer code to be able to delete the address 1002? And is the engineering code always the same or is it changeable by the company who first installed the system in my old shop? thanks in advance, Henrik. You need to mark zone 1002 as spare which i believe is option 52 on galaxy On 24/10/2020 at 21:16, PeterJames said: okay a higher chance then Still doubt it the monkeys still haven't had thier bananas Edited October 28, 2020 by Imnotshankled Quote
Henrik Posted October 28, 2020 Author Posted October 28, 2020 Am I doing this in the right order when trying to access the eng mode? 48 ent, 1 ent, 1 ent, 1 ent (eng code) ent? When I do this nothing happens. does it tell me I have entered the wrong eng code or not? Quote
james.wilson Posted October 29, 2020 Posted October 29, 2020 No you just enter the engineer code from day Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
al-yeti Posted October 29, 2020 Posted October 29, 2020 3 hours ago, james.wilson said: No you just enter the engineer code from day Thought it has to be enabled ? 19 hours ago, Henrik said: Ok guys, got everything up and running just fine. i do however have an slight issue. when I took the alarm down I most have missed one PIR hanging on the wall (address 1002). how do I go about entering the engineer code to be able to delete the address 1002? And is the engineering code always the same or is it changeable by the company who first installed the system in my old shop? thanks in advance, Henrik. While your stuck get a resistor and put it across 1k and it should stop it from throwing the error until you work something out Quote
james.wilson Posted October 29, 2020 Posted October 29, 2020 14 minutes ago, al-yeti said: Thought it has to be enabled ? good point it does, for some reason i thought it was a classic Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
al-yeti Posted October 29, 2020 Posted October 29, 2020 12 minutes ago, james.wilson said: good point it does, for some reason i thought it was a classic Classis is me lol So enable in menu 48 , and then enter engineer code But OP more than likely you don't have it so try the resistor and then you might be lucky if it's all user reset Quote
Henrik Posted October 29, 2020 Author Posted October 29, 2020 3 hours ago, al-yeti said: Classis is me lol So enable in menu 48 , and then enter engineer code But OP more than likely you don't have it so try the resistor and then you might be lucky if it's all user reset Did put a 1K between 1002 and 0V but still getting the +SAB fault code on 1002 and did nothing, also got the same code on 1003 but I got all the cables in the right places gonna try a Wago clip just to see if its the cables that's not connected properly. No one out there that could help me via PM on how to reset this system of mine? Quote
al-yeti Posted October 29, 2020 Posted October 29, 2020 49 minutes ago, Henrik said: Did put a 1K between 1002 and 0V but still getting the +SAB fault code on 1002 and did nothing, also got the same code on 1003 but I got all the cables in the right places gonna try a Wago clip just to see if its the cables that's not connected properly. No one out there that could help me via PM on how to reset this system of mine? You got a picture of where you put resister? Quote
al-yeti Posted October 29, 2020 Posted October 29, 2020 50 minutes ago, Henrik said: Did put a 1K between 1002 and 0V but still getting the +SAB fault code on 1002 and did nothing, also got the same code on 1003 but I got all the cables in the right places gonna try a Wago clip just to see if its the cables that's not connected properly. No one out there that could help me via PM on how to reset this system of mine? Must mean zone 2 was being used as a sab tamper maybe? But earlier you said it was a PIR So when you say you get +sab and 1002 are you sure these are not separate faults and your not confusing matters Quote
