Henrik Posted October 23, 2020 Author Posted October 23, 2020 2 hours ago, al-yeti said: Leave coms til last , mount your panel and keypad , c078 , and the coms boards should already be mounted hopefully Switch on and see what faults you get, work through one by one You see that’s the problem, what should go through the C078 and what goes straight to the box? Should I have the keypad go in on 12V 0V A B on the right hand side? And what should I have going to OP2? I’ll post some pictures on how it look after I cut the cables. Maybe someone would be able to say what equipment been connected to what port. Quote
norman Posted October 23, 2020 Posted October 23, 2020 14 minutes ago, Henrik said: No, apparently not! Bizarre Quote Nothing is foolproof to a sufficiently talented fool.
GalaxyGuy Posted October 23, 2020 Posted October 23, 2020 Yes, op, the keypad and RIO go to the rs485 bus on the right. Quote
PeterJames Posted October 23, 2020 Posted October 23, 2020 2 hours ago, Henrik said: Unfortunately I’m not aloud to have a wireless alarm system due to having a goldsmith studio in the basement. My insurance company demand a wired alarm system. I would be double checking what your policy says if I were you, I think it highly unlikely that an insurance company would accept anything less than a system installed by an accredited company with at least dual-path grade 3 monitoring. I would expect that a goldsmith studio will hold theft attractive stock and property, and I would expect the value of the contents to be in the thousands not the hundreds. Does your policy mention Police response? Just trying to save you a whole lot of heartache Quote
Henrik Posted October 23, 2020 Author Posted October 23, 2020 1 hour ago, Hillbilly said: Oh it’s going to be a long install! not necessary. Quote
Henrik Posted October 23, 2020 Author Posted October 23, 2020 1 hour ago, PeterJames said: I would be double checking what your policy says if I were you, I think it highly unlikely that an insurance company would accept anything less than a system installed by an accredited company with at least dual-path grade 3 monitoring. I would expect that a goldsmith studio will hold theft attractive stock and property, and I would expect the value of the contents to be in the thousands not the hundreds. Does your policy mention Police response? Just trying to save you a whole lot of heartache I have checked with the insurance company and as long as I can prove the system works and with video recording in the event of an break in it ok. I do not have to have police or security company response for the insurance. Absolutely true about the money, it’s well over 10s of thousand in storage. Quote
Henrik Posted October 23, 2020 Author Posted October 23, 2020 But enough about my insurance. is there anyone that could help me a bit with the wiring of this system? if this was your system how would you hook it up (with all the marks on the equipment mentioned). Quote
PeterJames Posted October 23, 2020 Posted October 23, 2020 2 minutes ago, Henrik said: I have checked with the insurance company and as long as I can prove the system works and with video recording in the event of an break in it ok. I do not have to have police or security company response for the insurance. Absolutely true about the money, it’s well over 10s of thousand in storage. Wouldn't happen in the UK, insurers like to cover their bets here Quote
al-yeti Posted October 23, 2020 Posted October 23, 2020 16 minutes ago, Henrik said: But enough about my insurance. is there anyone that could help me a bit with the wiring of this system? if this was your system how would you hook it up (with all the marks on the equipment mentioned). But we already told you where to start? Are you basically saying you don't have a clue how to find the manual to atleast wire the keypad to the control panel If you can't get that bit done , I would forget Bout this ..... Quote
