Scouse412 Posted October 30, 2020 Posted October 30, 2020 Hi I'm Installing a ACCENTA Alarm Panel together with a PyronixV2 speech dailer, and I'm not sure how to connect up the auto dialer to the alarm panel any help would be apricated thanks Quote
al-yeti Posted October 30, 2020 Posted October 30, 2020 25 minutes ago, Scouse412 said: Hi I'm Installing a ACCENTA Alarm Panel together with a PyronixV2 speech dailer, and I'm not sure how to connect up the auto dialer to the alarm panel any help would be apricated thanks The speech dialler has a Negative Positive Trigger Phone connections As a basic Negative to negative Positive to 12v+ aux Trigger can connect to the bell trigger which you may need to setup on the v2tel side after Phone connections to 2&5 of your extension socket , not the master side will be easiest for you Although if you got opportunity to return the dialler and get a GSM version you maybe better off future wise Quote
