netkey11 Posted November 2, 2020 Posted November 2, 2020 Hallo I want to install 16 POE cameras. The distance between POE cameras and POE NVR is 140m/460ft. Can i put my 16 channel POE Switch in the middle of the distance ( POE Switch insted of POE Extender), and then from the POE switch to the Router with just 1 Cable. Or do you have better idea? Quote
sixwheeledbeast Posted November 2, 2020 Posted November 2, 2020 Ethernet is 100m max normally for an installation 90m field wiring with 10m left for patching. You then also need to consider the load types and how much your switch provides. Quote
sixwheeledbeast Posted November 2, 2020 Posted November 2, 2020 There are other brands of kit that offer longer ranges but it's not Ethernet they normally have some "CCTV mode", like above. Quote
al-yeti Posted November 3, 2020 Posted November 3, 2020 9 hours ago, PeterJames said: Unless you use Dahua EPOE There's nothing special your showing here with repeaters and coax lol 1 Quote
PeterJames Posted November 3, 2020 Posted November 3, 2020 11 hours ago, al-yeti said: There's nothing special your showing here with repeaters and coax lol the bit your looking at is traditional there are no epoe cams? Below the top camera is not poe, the three below that are epoe, all of em will do what the op wants Quote
al-yeti Posted November 4, 2020 Posted November 4, 2020 13 hours ago, PeterJames said: the bit your looking at is traditional there are no epoe cams? Below the top camera is not poe, the three below that are epoe, all of em will do what the op wants Ok but nothing others can't do right ? Quote
PeterJames Posted November 4, 2020 Posted November 4, 2020 I dont know about others the epoe does what the op asked, which was my answer to the question Quote
al-yeti Posted November 4, 2020 Posted November 4, 2020 Just now, PeterJames said: I dont know about others the epoe does what the op asked, which was my answer to the question Ok I get you So upto 800m no device in-between? Quote
PeterJames Posted November 4, 2020 Posted November 4, 2020 5 hours ago, al-yeti said: Ok I get you So upto 800m no device in-between? yep over 1k if you put coax in the middle not that Ive tried it Quote
