MrHappy Posted November 12, 2020 Posted November 12, 2020 6 minutes ago, scrimshanker said: I see a national (Abel Alarm Company) and a large regional (Wessex Group) are fitting it, so can't be that bad. Yale where asking too much ? 1 Quote Mr Veritas God
al-yeti Posted November 12, 2020 Posted November 12, 2020 (edited) 1 hour ago, scrimshanker said: well there you go then, not sure what a GMX account is. Guessing google mail I see a national (Abel Alarm Company) and a large regional (Wessex Group) are fitting it, so can't be that bad. So how many you install? Edited November 12, 2020 by al-yeti Quote
scrimshanker Posted November 13, 2020 Author Posted November 13, 2020 None! Are you a little special? I don't do alarms, I was just asking as I saw these being banded around along with ring cameras. Quote
al-yeti Posted November 13, 2020 Posted November 13, 2020 9 minutes ago, scrimshanker said: None! Are you a little special? I don't do alarms, I was just asking as I saw these being banded around along with ring cameras. Just asking? More than just asking dude ...... You mean like special brew ? Your favourite? 3 Quote
norman Posted November 13, 2020 Posted November 13, 2020 35 minutes ago, scrimshanker said: None! Are you a little special? I don't do alarms, I was just asking as I saw these being banded around along with ring cameras. What was your question to them on your support ticket? Quote Nothing is foolproof to a sufficiently talented fool.
al-yeti Posted November 13, 2020 Posted November 13, 2020 15 minutes ago, norman said: What was your question to them on your support ticket? Can't get it to work help? 1 1 Quote
sixwheeledbeast Posted November 13, 2020 Posted November 13, 2020 21 hours ago, sixwheeledbeast said: Maybe your not but it comes across that way. Seems I was right. Something clearly doesn't add up here, good luck with whatever this thread was suppose to achieve. 1 1 Quote
scrimshanker Posted November 15, 2020 Author Posted November 15, 2020 Norman see below On 11 Nov 2020, at 08:19, Ajax Systems <support@ajax.systems> wrote: Subject: UK grading of system Comment: Hi Does your alarm system conform to the current UK intruder alarm standards and if so which grade is your alarm. Also, can you confirm whether your system communicates with its detectors with one way or two way communication As for the other two, im sorry I wasn't listen to you. what was your comment? Quote
Amina Posted December 13, 2022 Posted December 13, 2022 On 10/11/2020 at 14:27, al-yeti said: Graded by who? You actually read all the chinglish online or just making this up as you go along ? Ajax is certified with Grade 2 by TrezorTest, an accredited Czech company with an excellent reputation in Europe https://ajax.systems/blog/what-is-a-security-grade/ Quote
al-yeti Posted December 13, 2022 Posted December 13, 2022 7 hours ago, Amina said: Ajax is certified with Grade 2 by TrezorTest, an accredited Czech company with an excellent reputation in Europe https://ajax.systems/blog/what-is-a-security-grade/ So basically not certified in uk Quote
