Mark Rider Posted November 8, 2020 Author Posted November 8, 2020 No good won't start with it all disconect Quote
Amps Posted November 8, 2020 Posted November 8, 2020 5 hours ago, al-yeti said: They don't exactly make it hard to get dude , just like wintex etc All aimed at DIY trying to show they trade lol Thought you had to be a registered installer? Quote
al-yeti Posted November 8, 2020 Posted November 8, 2020 12 minutes ago, Amps said: Thought you had to be a registered installer? Anyone register with some companies just blag it Even with hikvision you can get away with it and blag it But you couldn't get hkc software without being registered the software itself keeps tabs on you , and they know when you download it and login Quote
Amps Posted November 8, 2020 Posted November 8, 2020 4 minutes ago, al-yeti said: Anyone register with some companies just blag it Even with hikvision you can get away with it and blag it But you couldn't get hkc software without being registered the software itself keeps tabs on you , and they know when you download it and login Ok didn't realise it was that easy. You think the software always linked to a email address? Just wondering how companies stop rouge engineers logging in after they have left the company. Quote
al-yeti Posted November 8, 2020 Posted November 8, 2020 1 hour ago, Amps said: Ok didn't realise it was that easy. You think the software always linked to a email address? Just wondering how companies stop rouge engineers logging in after they have left the company. Don't know , but now are you not talking about logging into panel? As for software you can create more users and delete when they leave Not sure how others work but seems to work for hkc Quote
Zimmerphrame- Posted October 23, 2021 Posted October 23, 2021 can be a dodgy transformer or high resistance short...you'd need to check the voltage across 12v/0v aux.. try disconnecting all the 12v/0v terminals and checking 12v/0v aux voltages again, if it goes back to the normal 13.5-ishV, then its likely something wired in causing the issue. add a pair of 12v/0v at a time to see if values change.. Quote
