1 hour ago, btssn said:
I don't think client wants to spend more than £50 - £80 current simple set reader has failed is reason for upgrade
Including labour?
1 minute ago, btssn said:
  I shall hope not ?
What about a max 4 set in standalone mode maybe you can use it to set u set , the Honeywell uses a set key switch input ? I can't remember really
But you would need the prox tags aswell so £50 no good
But what Pete said should work , although a stand alone hkc keypad would do it to if your in the trade
  • Thanks 1
hmm the galaxy max 4 is more expensive, client is bit cheap skate lolz, i will check manual i believe it uses key switch input so the ss2 could be used to set and unset, i do not need fancy lights as will be fitting next to keypad so just simple set and unset.
8 hours ago, james.wilson said:
I think you will struggle, the gen 4 prox option was popular, while fobs can be sorted hardware can't. I'd suggest a panel change
Already suggested however customer does not want to spend that kind of money may just leave them with keypad until they get fed up.
