al-yeti Posted November 18, 2020 Posted November 18, 2020 (edited) 31 minutes ago, btssn said: would the galaxy mk7 keypad work with this panel as they have built in prox fob No man You should tell customer you cant help and if he doesn't upgrade the panel from you he will end up getting someone else to do the same thing And walk away ? Edited November 18, 2020 by al-yeti 2 Quote
norman Posted November 18, 2020 Posted November 18, 2020 *this Quote Nothing is foolproof to a sufficiently talented fool.
james.wilson Posted November 18, 2020 Posted November 18, 2020 No the keypad has to match the panel 1 Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
btssn Posted November 18, 2020 Author Posted November 18, 2020 42 minutes ago, james.wilson said: No the keypad has to match the panel Did think so Sounds like a plan Quote
MrHappy Posted November 18, 2020 Posted November 18, 2020 replace the controls & keypad- euromini or similar ? if you not an alarm man it s probably easier to get it done than spend the day trying to work it out... 1 Quote Mr Veritas God
btssn Posted November 22, 2020 Author Posted November 22, 2020 Thanks told customer only option is upgrade panel and keypad Quote
norman Posted November 23, 2020 Posted November 23, 2020 You know it makes sense... Quote Nothing is foolproof to a sufficiently talented fool.
btssn Posted November 23, 2020 Author Posted November 23, 2020 Just now, norman said: You know it makes sense... I totally agree however you know some customers try to be cheap Quote
norman Posted November 23, 2020 Posted November 23, 2020 Yup, the ones you don't want though, only cause pain in the longrun. Quote Nothing is foolproof to a sufficiently talented fool.
btssn Posted November 23, 2020 Author Posted November 23, 2020 Just now, norman said: Yup, the ones you don't want though, only cause pain in the longrun. It's so true they always become a problem later down the line as well. Quote
