btssn Posted November 17, 2020 Author Posted November 17, 2020 (edited) I guess i could use door entry fob to set and unset system something like this https://www.doorentryonline.co.uk/acatalog/SR2-Proximity-card-key-fob-reader.html Edited November 17, 2020 by btssn add info Quote
al-yeti Posted November 17, 2020 Posted November 17, 2020 1 hour ago, btssn said: I don't think client wants to spend more than £50 - £80 current simple set reader has failed is reason for upgrade Including labour? Quote
btssn Posted November 17, 2020 Author Posted November 17, 2020 Just now, al-yeti said: Including labour? I shall hope not Quote
al-yeti Posted November 17, 2020 Posted November 17, 2020 1 minute ago, btssn said: I shall hope not What about a max 4 set in standalone mode maybe you can use it to set u set , the Honeywell uses a set key switch input ? I can't remember really But you would need the prox tags aswell so £50 no good But what Pete said should work , although a stand alone hkc keypad would do it to if your in the trade 1 Quote
btssn Posted November 17, 2020 Author Posted November 17, 2020 hmm the galaxy max 4 is more expensive, client is bit cheap skate lolz, i will check manual i believe it uses key switch input so the ss2 could be used to set and unset, i do not need fancy lights as will be fitting next to keypad so just simple set and unset. Quote
james.wilson Posted November 18, 2020 Posted November 18, 2020 I think you will struggle, the gen 4 prox option was popular, while fobs can be sorted hardware can't. I'd suggest a panel change Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
btssn Posted November 18, 2020 Author Posted November 18, 2020 8 hours ago, james.wilson said: I think you will struggle, the gen 4 prox option was popular, while fobs can be sorted hardware can't. I'd suggest a panel change Already suggested however customer does not want to spend that kind of money may just leave them with keypad until they get fed up. Quote
btssn Posted November 18, 2020 Author Posted November 18, 2020 10 hours ago, al-yeti said: But what Pete said should work , although a stand alone hkc keypad would do it to if your in the trade Do you mean this keypad would keypad function ? most likely not however could be wired to use rf to set and unset https://www.hkcsecurity.com/en-GB/products/intrusion-keypads/rf-rkp---rf-remote-keypad-/ Quote
btssn Posted November 18, 2020 Author Posted November 18, 2020 would the galaxy mk7 keypad work with this panel as they have built in prox fob Quote
