James R Posted November 27, 2020 Posted November 27, 2020 Hi all, I am stepping into intruder alarms after being a sparks for nearly 20 yrs. I am part of a firm who just does intruder alarms now and feel like an apprentice again but want to learn from the ground up... Any advice of any sort from seasoned intruder alarm installers would be much appreciated Regards Quote
Imnotshankled Posted November 27, 2020 Posted November 27, 2020 15 minutes ago, James R said: Hi all, I am stepping into intruder alarms after being a sparks for nearly 20 yrs. I am part of a firm who just does intruder alarms now and feel like an apprentice again but want to learn from the ground up... Any advice of any sort from seasoned intruder alarm installers would be much appreciated Regards Some helpful advise if you see a paragon panel rip it off the wall and stamp on it immediately 2 Quote
James R Posted November 27, 2020 Author Posted November 27, 2020 I heard that it Is it a trueism that a sparks could be an alarm engineer, but an alarm engineer couldn't be a sparks... Any truth in that? Personally I believe they are 2 completely different disciplines. Quote
James R Posted November 27, 2020 Author Posted November 27, 2020 18 minutes ago, Imnotshankled said: Some helpful advise if you see a paragon panel rip it off the wall and stamp on it immediately Which is the 'best' intruder alarm system you have installed? Quote
al-yeti Posted November 27, 2020 Posted November 27, 2020 1 hour ago, James R said: Which is the 'best' intruder alarm system you have installed? What does your company install? And can you train there ? Quote
KWCFC Posted November 27, 2020 Posted November 27, 2020 I converted to security about 6 years ago after being a sparks... I do prefer it but best advice I can give you is make sure you learn as much as you can from your colleagues as the information isn't as widely available on the Internet as it is for sparks. If it's just intruder alarms then there's not much to worry about but it does get complicated if you need to integrate it with CCTV and access control etc on a large commercial. As for what's the best intruder alarm... There isn't one. If you asked 5 different alarm engineers what the best panel is they will name 5 different brands. Alarm engineers tend to fit the brands that they are experienced in and know inside out. The actual concept of an alarm is the same amongst all the brands but they all have their own menu setups and characteristics. 2 Quote
Imnotshankled Posted November 27, 2020 Posted November 27, 2020 2 hours ago, James R said: Which is the 'best' intruder alarm system you have installed? Euro 46 app is what i fit Quote
Imnotshankled Posted November 27, 2020 Posted November 27, 2020 1 hour ago, al-yeti said: What does your company install? And can you train there ? This? 1 Quote
James R Posted November 28, 2020 Author Posted November 28, 2020 4 hours ago, KWCFC said: I converted to security about 6 years ago after being a sparks... I do prefer it but best advice I can give you is make sure you learn as much as you can from your colleagues as the information isn't as widely available on the Internet as it is for sparks. If it's just intruder alarms then there's not much to worry about but it does get complicated if you need to integrate it with CCTV and access control etc on a large commercial. As for what's the best intruder alarm... There isn't one. If you asked 5 different alarm engineers what the best panel is they will name 5 different brands. Alarm engineers tend to fit the brands that they are experienced in and know inside out. The actual concept of an alarm is the same amongst all the brands but they all have their own menu setups and characteristics. Thanks. Yes, that makes sense. We use texecom premier elite - but also look after sites that have All sorts of makes/models of intruder alarms Also into access control - networked stuff (Paxton, salto, interflex) and auto doors, gates, barriers, roller shutters etc it's like being an apprentice - again at the tender age of 35 Quote
James R Posted November 28, 2020 Author Posted November 28, 2020 3 hours ago, Imnotshankled said: This? Class. Never thought of that - however I prefer to put the joins in an ice cream tub. Quote
