PSE Posted November 28, 2020 Posted November 28, 2020 1 minute ago, MrHappy said: nice to see your still lurking I’m never far away mate, How’s tricks... Everyone keeping well under the circumstances Quote
PSE Posted November 28, 2020 Posted November 28, 2020 Just now, James R said: That looks good - as a background as a sparks I would have just used 20mm galv conduit - is that stuff easier to install? Obvs galv conduit is a c*nt Very easy to use, 12mm Diameter only. Fir a nice clean but free cut, I use a standard 15mm copper pipe cutter.. nice and neat with no jagged edges Quote
James R Posted November 28, 2020 Author Posted November 28, 2020 14 minutes ago, MrHappy said: An EOL circuit is 2 wires, these have been twisted together to make pair of cables I'd use a drill, with a hook in the chuck The pic is not my work but that of @PSE mine look better with the lid on My cabling also looks like a F-ing masterpiece when the ceiling tiles are back in Quote
James R Posted November 28, 2020 Author Posted November 28, 2020 2 minutes ago, PSE said: Very easy to use, 12mm Diameter only. Fir a nice clean but free cut, I use a standard 15mm copper pipe cutter.. nice and neat with no jagged edges Nice... What's the prices like on that gear? Had to do a whole job (sparky) in stainless steel conduit before... Nearly died in the process lol Quote
Imnotshankled Posted November 28, 2020 Posted November 28, 2020 (edited) 38 minutes ago, James R said: Panel in the roofspace... F*ck roofspace lol Saw your installation today disappointed My head hurts as the 7ah fell out Edited November 28, 2020 by Imnotshankled Quote
James R Posted November 28, 2020 Author Posted November 28, 2020 4 minutes ago, Imnotshankled said: Saw your installation today disappointed My head hurts as the 7ah fell out Wheres that? At least the garage door wont end in front of the dB cover when you have it up - that's something Quote
al-yeti Posted November 28, 2020 Posted November 28, 2020 4 hours ago, James R said: Drill with a hook to twist the cables--like that... Your not taking the piss are you? You have fitted some alarms with someone yet? Quote
PSE Posted November 28, 2020 Posted November 28, 2020 Never used a hook in the drill myself, I just use a specific Bosch mini 12v drill and bang the pair straight into the chuck. Literally 5 seconds on reverse spin and it’s done, nice neat pairs all looking identical and even twists. Quote
James R Posted November 29, 2020 Author Posted November 29, 2020 52 minutes ago, al-yeti said: You have fitted some alarms with someone yet? Y but Not enough mate Quote
norman Posted November 29, 2020 Posted November 29, 2020 1 hour ago, PSE said: Never used a hook in the drill myself, I just use a specific Bosch mini 12v drill and bang the pair straight into the chuck. Literally 5 seconds on reverse spin and it’s done, nice neat pairs all looking identical and even twists. Same bend the ends over for a better grip then trim to size. Also worked really well with ceiling grid wire, used to get rolls from the skips and do metres at a time and cut to length for fish wires. Quote Nothing is foolproof to a sufficiently talented fool.
