1 minute ago, MrHappy said:
nice to see your still lurking ?
I’m never far away mate, How’s tricks... Everyone keeping well under the circumstances
Just now, James R said:
That looks good - as a background as a sparks I would have just used 20mm galv conduit - is that stuff easier to install? Obvs galv conduit is a c*nt
Very easy to use, 12mm Diameter only.
Fir a nice clean but free cut, I use a standard 15mm copper pipe cutter.. nice and neat with no jagged edges
14 minutes ago, MrHappy said:
An EOL circuit is 2 wires, these have been twisted together to make pair of cables
I'd use a drill, with a hook in the chuck
The pic is not my work but that of @PSE
mine look better with the lid on ?
My cabling also looks like a F-ing masterpiece when the ceiling tiles are back in?
Nice... What's the prices like on that gear? Had to do a whole job (sparky) in stainless steel conduit before... Nearly died in the process lol
Posted (edited)
38 minutes ago, James R said:
Panel in the roofspace... F*ck roofspace lol
Saw your installation today     disappointed
My head hurts as the 7ah fell out
Edited by Imnotshankled
Wheres that? At least the garage door wont end in front of the dB cover when you have it up - that's something ?
4 hours ago, James R said:
Drill with a hook to twist the cables--like that... Your not taking the piss are you? ?
You have fitted some alarms with someone yet?
Never used a hook in the drill myself, I just use a specific Bosch mini 12v drill and bang the pair straight into the chuck. Literally 5 seconds on reverse spin and it’s done, nice neat pairs all looking identical and even twists.
Same bend the ends over for a better grip then trim to size.
Also worked really well with ceiling grid wire, used to get rolls from the skips and do metres at a time and cut to length for fish wires.
