GalaxyGuy Posted November 30, 2020 Posted November 30, 2020 On 28/11/2020 at 20:59, James R said: Panel - gprs comms module- ip comms module - 15 dt pirs... I'm thinking I'm gonna set it up and program in the office before I hand it to my installer. If port forwarding for use with the GX app, you can only lock down the RSS and UMS passwords with RSS at the moment. In saying that, the best advice is to use a VPN rather than opening ports up. Quote
James R Posted November 30, 2020 Author Posted November 30, 2020 18 hours ago, GalaxyGuy said: If port forwarding for use with the GX app, you can only lock down the RSS and UMS passwords with RSS at the moment. In saying that, the best advice is to use a VPN rather than opening ports up. Hi, dont have the RSS. Can't justify the cost as we don't do a lot of galaxy. One question, got an ip module that's been specced - would that just connect to customers network to be able to use the app? Regards Quote
James R Posted November 30, 2020 Author Posted November 30, 2020 18 hours ago, GalaxyGuy said: If port forwarding for use with the GX app, you can only lock down the RSS and UMS passwords with RSS at the moment. In saying that, the best advice is to use a VPN rather than opening ports up. They also specced a gsm/gprs comms module - we are setting up radio/radio Dualcom for keyholder monitoring, I take it there's no need for the honeywell module as well? Quote
GalaxyGuy Posted November 30, 2020 Posted November 30, 2020 3 hours ago, James R said: They also specced a gsm/gprs comms module - we are setting up radio/radio Dualcom for keyholder monitoring, I take it there's no need for the honeywell module as well? No, but it can be used for direct SMS. The Ethernet module can be used for the gx app, allowing remote control. Quote
al-yeti Posted November 30, 2020 Posted November 30, 2020 3 hours ago, James R said: They also specced a gsm/gprs comms module - we are setting up radio/radio Dualcom for keyholder monitoring, I take it there's no need for the honeywell module as well? If you can avoid the app do so , it's messy , the selfmon virtual keypad might do them if they want to set from bed lol Quote
