James R Posted December 1, 2020 Posted December 1, 2020 Hi all Got a Gardtec panel that has 2 panic alarm wireless fobs as zones 92 and 93 When customer started setting procedure - alarm wouldn't set and got a alert message on one of the panic fobs - wouldn't reset with engineers code and kept into 'alert! Enter code' or something to that effect. It leads me to think the panel thinks the fob is being pressed due to a fault and won't set as a result - all the alarm reset codes are either 'any code' or 'engineers code' so I don't think there's a different code that I don't know for PA reset. Wondered if any one has had similar issues? Or have any info Regards Quote
James R Posted December 1, 2020 Author Posted December 1, 2020 Hi all Got a Gardtec panel that has 2 panic alarm wireless fobs as zones 92 and 93 When customer started setting procedure - alarm wouldn't set and got a alert message on one of the panic fobs - wouldn't reset with engineers code and kept into 'alert! Enter code' or something to that effect. It leads me to think the panel thinks the fob is being pressed due to a fault and won't set as a result - all the alarm reset codes are either 'any code' or 'engineers code' so I don't think there's a different code that I don't know for PA reset. Wondered if any one has had similar issues? Or have any info Regards Quote
al-yeti Posted December 1, 2020 Posted December 1, 2020 2 hours ago, James R said: Hi all Got a Gardtec panel that has 2 panic alarm wireless fobs as zones 92 and 93 When customer started setting procedure - alarm wouldn't set and got a alert message on one of the panic fobs - wouldn't reset with engineers code and kept into 'alert! Enter code' or something to that effect. It leads me to think the panel thinks the fob is being pressed due to a fault and won't set as a result - all the alarm reset codes are either 'any code' or 'engineers code' so I don't think there's a different code that I don't know for PA reset. Wondered if any one has had similar issues? Or have any info Regards Might not help much , it's normal all these weird faults on disco gear But most hate them here ,H might know or asicc dude whatever his sign on is lol Silly question is button stuck? Batteries changed or just tested , powered down and up to see if it clears , or try new fob Quote
aissecur Posted December 2, 2020 Posted December 2, 2020 Have you put new batteries in the fob? may be worth deleting the fobs & then relearning them If you delete them, learn one, test it if all ok learn the other Quote
James R Posted December 2, 2020 Author Posted December 2, 2020 11 hours ago, aissecur said: Have you put new batteries in the fob? may be worth deleting the fobs & then relearning them If you delete them, learn one, test it if all ok learn the other Hi, the alarm was serviced recently (couple of weeks) batts changed... Yeah, I gonna get a new one, learn it on and take it from there. Regards 20 hours ago, al-yeti said: Might not help much , it's normal all these weird faults on disco gear But most hate them here ,H might know or asicc dude whatever his sign on is lol Silly question is button stuck? Batteries changed or just tested , powered down and up to see if it clears , or try new fob Is the general consensus on this site that risco gear is pony? Quote
al-yeti Posted December 2, 2020 Posted December 2, 2020 2 minutes ago, James R said: Hi, the alarm was serviced recently (couple of weeks) batts changed... Yeah, I gonna get a new one, learn it on and take it from there. Regards Is the general consensus on this site that risco gear is pony? More than pony on this site.... Quote
James R Posted December 2, 2020 Author Posted December 2, 2020 3 minutes ago, al-yeti said: More than pony on this site.... Got a lot of sites where the previous 'ahem' contracter has put risco pa alarm fobs everywhere - would you recommend swapping them out? Quote
al-yeti Posted December 2, 2020 Posted December 2, 2020 3 minutes ago, James R said: Got a lot of sites where the previous 'ahem' contracter has put risco pa alarm fobs everywhere - would you recommend swapping them out? I don't like there equipment , but some her do use some stuff , there wireless is dodgy But you will get better evaluation from others , there's plenty of threads on the stuff trade side Once you had your covict19 jab they will let you in Quote
James R Posted December 2, 2020 Author Posted December 2, 2020 6 minutes ago, al-yeti said: I don't like there equipment , but some her do use some stuff , there wireless is dodgy But you will get better evaluation from others , there's plenty of threads on the stuff trade side Once you had your covict19 jab they will let you in We use texecom as standard. Had a few issues with risco wireless gear recently. Something we're having to look after.. Installers by previous contactors - they must have loved as they've put everywhere Quote
al-yeti Posted December 2, 2020 Posted December 2, 2020 6 minutes ago, James R said: We use texecom as standard. Had a few issues with risco wireless gear recently. Something we're having to look after.. Installers by previous contactors - they must have loved as they've put everywhere Odd it's not even that cheap , unless they had special deals I suppose .... Quote
