I am all for keeping serviceable well maintained systems irrelevant of age. From the pictures I wouldn't be wasting time on that mess and want to be upgrading it.
You can't expect a cheap domestic onboard panel to work in a dusty/dirty environment for very long.
It also appears to have been lacking any maintenance with one of those batteries in and what's with the two woodscrews holding the transformer in...
  • Upvote 2
  • 6 months later...
Posted (edited)
James Wilson Said "When first powered up its in a test mode showing open circuits. Once you clear them all it will then go to rest / day mode.   One option is to remove all circuit wiring (marking up first and take a photo) then link out all to prove the panel. If the panel functions with all circuits, tampers etc closed then you have a base point to start from"
and that's your answer - it works, it worked for me.
Edited by sixwheeledbeast
No defaulting information
Posted (edited)
Since the last post was Dec 2020 your a bit late to the party
as above
