If your texe bell box doesn't sound with a Euro46 panel it's because the Euro46 bell o/p is +... texe Bell boxes looks for a neg so either connect your bell to strobe or use a very handy relay to convert bell+ to neg.
Regards
  • 4 weeks later...
Connect the bell to the strobe?...
You'll get the bell ringing on a day mode tamper
I would suggest find or make (relay etc) a suitable "-ve bell mimic" output
Bit odd to have +ve trig default on modern stuff anyway tho...
I think your mistaken.
Neg trigger for both bell & strobe, negtive tamper return
I've never inverted the bell or strobe trigger, IIRC I believe you can only invert the digi pin on the "rainbow ribbon" ?
Thanks for the replies.
All I can say was that the texecom bell box would not sound with bell connected to bell in the euro 46 panel - in bell test giving +   as soon as I gave it -   it worked.  That's all I can say.
Had a look at the manual to see if you can change the polarity of the bell O/P - didn't find anything or i'm being thick
Regards
Regards
Regards
Bell jumpers ?
  • Upvote 1
On 19/01/2021 at 06:47, al-yeti said:
Bell jumpers ?
Didn't see a jumper in the bell that would convert polarity.
I was thinking a non latching/very handy relay at the panel to convert.
