Mirez Posted December 26, 2020 Posted December 26, 2020 Evening & seasons greetings I'm after some advice on an alarm system that's installed in my house (recently moved into). The current system is a TS900 with 3 LCD panels a node expander, 12 PIRS, 3 contact sensors and 4 fire detectors. The house also has a separate door access system with proximity readers - guess the previous owner was quite into his tech Given I have prox tags for the doors and that the primary panel's buttons seem not to be that responsive, it would be nice if the alarm system could be set/unset using them (like my previous house) when I replace that panel. I started looking at options and noticed the MKP3 and TS900+ work together and would appear to give this function. I can't find a lot of info on the difference between the TS900 and the plus though? I'm not entirely sure if they aren't one and the same tbh! Does anyone know if the MKP3 works with the TS900 to provide prox function? If not, I assume its either switching out the TS900 for the plus or replacing the whole system which seems a little extreme... Thanks in advance Quote
PeterJames Posted December 26, 2020 Posted December 26, 2020 Panel is obsolete, and I dont think it was ever prox, I could be wrong I was never a Menvier fan Quote
al-yeti Posted December 27, 2020 Posted December 27, 2020 11 hours ago, Mirez said: or replacing the whole system which seems a little extreme... Thanks in advance Extreme not to replace the whole thing Quote
MrHappy Posted December 27, 2020 Posted December 27, 2020 12 hours ago, Mirez said: I'm after some advice on an alarm system that's installed in my house (recently moved into). The current system is a TS900 with 3 LCD panels a node expander, 12 PIRS, 3 contact sensors and 4 fire detectors. The house also has a separate door access system with proximity readers - guess the previous owner was quite into his tech TS Networker finished cira 15yrs ago ? 12 hours ago, Mirez said: I started looking at options and noticed the MKP3 This for the M-Series which is also finished, the largest UK supplier has stock on order but it probably quicker & cheaper to look for new old stock on fleabay 12 hours ago, Mirez said: or replacing the whole system which seems a little extreme... I'd expect you'd be able to pay a man to renew the alarm with similar commercial quality kit for less than half of 1% of the value of the house. Quote Mr Veritas God
Mirez Posted December 28, 2020 Author Posted December 28, 2020 Thanks for the replies. So no easy way to get a prox then - that's fine. I'm not sure I understand the replace it replies though, why? Its perfectly functioning and I'm led to believe that the TS900 is a virtually bulletproof panel so give me some good reasoning why I should throw some money at it. Other then prox, what benefits / advancements have there been in alarm systems which can really justify any upgrade cost.... Quote
PeterJames Posted December 28, 2020 Posted December 28, 2020 3 minutes ago, Mirez said: the TS900 is a virtually bulletproof Do you have any virtual guns? Its like most things, in its day it probably was good, most here would say the same about the panels we installed 15 years ago. But its tech, and its been switched on for a long time, the longer its on the more warn out its getting. Most of us here have been installing for more years than that panel has been around, and from experience we can say that it will go wrong sooner or later. None of us have a crystal ball, but we all have experience of elderly panels failing at silly o clock in the morning or the day before someone wants to go on holiday. You could just wait till it goes wrong, and hope it fails at a convenient time. Or you could take the advice of experience and plan ahead. Its up to you we dont care either way. If you do decide to upgrade you will benefit from better features like fobs, smart-phone apps, better energy rating, (the panel is using electricity 24/7 old transformers are not as energy efficient as the latest switchmode psu's) and ultimately less false alarms. Quote
Mirez Posted December 28, 2020 Author Posted December 28, 2020 3 hours ago, PeterJames said: Do you have any virtual guns? Yes lots thanks, I use them to take pop-shots at people trying to make me spend money. I'm not trying to poo-poo the entire of an upgrade and I get this is your trade and how you make a living but as an electronic design engineer I'm not just going to accept "it's old" as a reason to spend money which is why I wanted some further info, Thanks for your input though, the additional benefits of a new panel don't seem to justify the expense so I will indeed just leave it but I'll be sure to curse you heavily if it fails at 2am Quote
al-yeti Posted December 28, 2020 Posted December 28, 2020 9 minutes ago, Mirez said: Yes lots thanks, I use them to take pop-shots at people trying to make me spend money. I'm not trying to poo-poo the entire of an upgrade and I get this is your trade and how you make a living but as an electronic design engineer I'm not just going to accept "it's old" as a reason to spend money which is why I wanted some further info, Thanks for your input though, the additional benefits of a new panel don't seem to justify the expense so I will indeed just leave it but I'll be sure to curse you heavily if it fails at 2am Ah ha design engineer Hence why your saying what your saying , I am like some others an electronics engineer , trained in it , so know exactly what nonsense your saying, not far off from the IT experts No offence by the way just striaght up, Conclusion leave it as is and don't waste your time. Quote
MrHappy Posted December 28, 2020 Posted December 28, 2020 12 minutes ago, Mirez said: but as an electronic design engineer I'm not just going to accept "it's old" I would assume it doesn't pay great if your not going pay the same £ as a cheap iphone to replace the controls ? I would also assume many a child has had a full on melt down over xmas as they got the "cheap" iphone Quote Mr Veritas God
PeterJames Posted December 28, 2020 Posted December 28, 2020 15 minutes ago, Mirez said: Yes lots thanks, I use them to take pop-shots at people trying to make me spend money. I get this is your trade and how you make a living but as an electronic design engineer I'm not just going to accept "it's old" as a reason to spend money which is why I wanted some further info, Thanks for your input though, the additional benefits of a new panel don't seem to justify the expense so I will indeed just leave it but I'll be sure to curse you heavily if it fails at 2am I wont make a penny from giving you advice, the time I spend on here is given up for free. Its not just old though its been powered up and running for the last 15/20 years Quote
