peterreynolds Posted January 13, 2021 Posted January 13, 2021 Hi, I fitted an Abacus alarm in my home many years ago (DIYer) and have maintained it since, my problem now is the LCD keypad buttons make poor contact and I opened the cover causing (Keypad Tamper Trbl) My question is if I fit a new keypad are my codes saved in the old keypad or the main alarm box or will the new keypad revert to the original default codes. Many Thanks, Peter. Quote
norman Posted January 13, 2021 Posted January 13, 2021 Codes will be saved in the NVM in the main control, assuming batteries are all OK. Quote Nothing is foolproof to a sufficiently talented fool.
peterreynolds Posted January 13, 2021 Author Posted January 13, 2021 On 13/01/2021 at 14:12, peterreynolds said: Hi, I fitted an Abacus alarm in my home many years ago (DIYer) and have maintained it since, my problem now is the LCD keypad buttons make poor contact and I opened the cover causing (Keypad Tamper Trbl) My question is if I fit a new keypad are my codes saved in the old keypad or the main alarm box or will the new keypad revert to the original default codes. Many Thanks, Peter. Expand On 13/01/2021 at 14:37, norman said: Codes will be saved in the NVM in the main control, assuming batteries are all OK. Expand On 13/01/2021 at 14:37, norman said: Codes will be saved in the NVM in the main control, assuming batteries are all OK. Expand Battery is good, I've attached picture of the type of LCD Keypad just to be sure. Quote
norman Posted January 13, 2021 Posted January 13, 2021 Codes are saved in the main control but just as a caveat it's not totally uncommon for older panels to corrupt or lose programming when down powered. More than likely OK but worst case you would have to update/replace the control panel Quote Nothing is foolproof to a sufficiently talented fool.
PeterJames Posted January 13, 2021 Posted January 13, 2021 Good luck finding a replacement keypad they havent made those for 20 years 1 Quote
peterreynolds Posted January 13, 2021 Author Posted January 13, 2021 Thanks Norman and Peter J, there's a couple available on ebay. Quote
al-yeti Posted January 13, 2021 Posted January 13, 2021 On 13/01/2021 at 15:19, peterreynolds said: Thanks Norman and Peter J, there's a couple available on ebay. Expand Plenty about lol , but I would upgrade Quote
PeterJames Posted January 13, 2021 Posted January 13, 2021 On 13/01/2021 at 15:19, peterreynolds said: Thanks Norman and Peter J, there's a couple available on ebay. Expand Couple of used 20 year old keypads that wont be much better than the one you have. I know its easier to just replace the keypad, but I think you could end up exactly where you are now after you have replaced it, only a bit poorer Quote
peterreynolds Posted January 13, 2021 Author Posted January 13, 2021 One is brand new in un-opened box, I sent the picture to them and they confirmed it is the same from old stock. 1 Quote
al-yeti Posted January 13, 2021 Posted January 13, 2021 On 13/01/2021 at 17:15, peterreynolds said: One is brand new in un-opened box, I sent the picture to them and they confirmed it is the same from old stock. Expand But an upgrade of panel and keypad is about £100? Even on basic like a 9651 with prox tags Quote
