Hi,
So I've successfully paired this keyfob so that I can set and unset the alarm, however the panic alarm just sends an SOS to the ARC and I want it to sound the siren.
I cannot find anything in the docs on how to do this, so if someone could advise it would be very much appreciated.
thanks in advance
1 hour ago, james.wilson said:
Oh ok
Dont know the flex that well.
If its not programmable (others will know more) you could link a circuit to an output (circuit programmed as PA, output programmed to follow the RF keyfob)
Does the galaxy have a silent pa setting?
13 hours ago, flexdiy said:
Hi James, thanks for the reply but as I say the panic function works just fine, it's just silent.
You need to program a link from the silent PA output to the bell output. This will not work on a trigger output, it needs to be a proper output.
