Kangaroo Posted February 7, 2021 Posted February 7, 2021 (edited) Hi, I am looking to upgrade the control box, keypad and PIRs but still using the existing 6 core cable. What would you recommend as a replacement for GARDTEC system? Looking for bells only in the first instance but would be interested in option for an auto dialler or smart systems that used wires and wireless, if possible. Thanks for your help in advance. KG Edited February 7, 2021 by Kangaroo Quote
sixwheeledbeast Posted February 7, 2021 Posted February 7, 2021 Every installer has there preferred manufacturers for a number of reasons. Most models would be fine with 6 core all round and will have some "smart" options. Some manufacturers these smart options are subscription via an installer only. Bells only would be no problem. Worth replacing your bellbox and testing the cabling while your at it. Quote
Kangaroo Posted February 7, 2021 Author Posted February 7, 2021 Thanks sixwheeledbeast for your reply. I have attached some images - any recommendations? Cheers KG Quote
PeterJames Posted February 7, 2021 Posted February 7, 2021 Any modern panel that you can lay your hands on. I wouldnt bother with a dialler though they will all be obsolete by 2025 Quote
Kangaroo Posted February 7, 2021 Author Posted February 7, 2021 PeterJames Thanks for you help, could I ask are all PIRs compatible with any control box? If not a dialler are you thinking network enable / use of internet? Cheers RK Quote
sixwheeledbeast Posted February 8, 2021 Posted February 8, 2021 Most PIR's will work with most systems when it comes to wired, wireless you would be stuck to the same manufacturer as the panel. For PIR's I'd look for minimum of "quads" or if required "dual-tech" and models with sealed optics so your Optex, Bosch as some examples. I don't care much for "smart" apps myself but take note of my initial post, if you want to guarantee your alarm gets a message to you, polled signalling via monitoring station would be required and you'd need an installer to do this. Maybe take a look at some older DIY threads, before taking on the project consider it may take you weeks and months of messing about whereas an installer could have it done in a day. Quote
