Stephen MD Posted February 13, 2021 Posted February 13, 2021 (edited) Not sure if it's the right place We moved into our house 2 years ago. It has an old active alarm system which we have never used (lights on main box alight as well as those on the room sensors). We are renovating the house and will be needing to remove the system. From yesterday it starts to beep Intermittently every 30 seconds. it's optima 2 plus alarm I found the engineer code and had looked at the manual after hours' effort resetting it still couldn't silent the beep. It doesn't quite mention such case and how-to in the manual. Can anyone adivse thanks! Edited February 13, 2021 by Stephen MD Quote
Stephen MD Posted February 13, 2021 Author Posted February 13, 2021 sorry to put the wrong title, it's optima 2 plus system Quote
PeterJames Posted February 13, 2021 Posted February 13, 2021 Check the batteries in your smoke detectors intruder alarms dont do intermittent beeps Quote
sixwheeledbeast Posted February 13, 2021 Posted February 13, 2021 As above will be your smoke detection. With doing work in the house your more likely to get dust in them. Also if it's PP3 batteries in them they're more likely to signal low voltage in cooler weather. Quote
al-yeti Posted February 13, 2021 Posted February 13, 2021 1 hour ago, PeterJames said: Check the batteries in your smoke detectors intruder alarms dont do intermittent beeps Yes they do I forget which one does the service beep Someone here made allot of money from there keypads ...... Quote
Stephen MD Posted February 13, 2021 Author Posted February 13, 2021 ohh thanks for the above remind the smoke alarm is just two years old I ruled it out in the first place Quote
