SteveC1458 Posted February 15, 2021 Posted February 15, 2021 We inherited a pyronix enforcer alarm which is now showing an alert on the main box , det wireless low battery Does this mean the battery on the wireless control box needs changing, or the battery on the main box, or something else? Quote
al-yeti Posted February 15, 2021 Posted February 15, 2021 On 15/02/2021 at 18:23, SteveC1458 said: We inherited a pyronix enforcer alarm which is now showing an alert on the main box , det wireless low battery Does this mean the battery on the wireless control box needs changing, or the battery on the main box, or something else? Expand Means you probably need to change all the batteries as one by one they will all go , so don't cheap skate it change all Quote
PeterJames Posted February 15, 2021 Posted February 15, 2021 On 15/02/2021 at 19:12, al-yeti said: Means you probably need to change all the batteries as one by one they will all go , so don't cheap skate it change all Expand We just took over the service on a Enforcer, the bats hadnt been replaced for four years, the manufacturer recommends 2 -3 years, we recommend every year, nothing worse than low battery just before you want to go on holiday 1 Quote
al-yeti Posted February 15, 2021 Posted February 15, 2021 On 15/02/2021 at 19:15, PeterJames said: We just took over the service on a Enforcer, the bats hadnt been replaced for four years, the manufacturer recommends 2 -3 years, we recommend every year, nothing worse than low battery just before you want to go on holiday Expand Enforcer poor on batteries , I rip them out , if in good Nik send to Hull 1 Quote
PeterJames Posted February 15, 2021 Posted February 15, 2021 I dont rate Pyronix never have done Quote
SteveC1458 Posted February 15, 2021 Author Posted February 15, 2021 On 15/02/2021 at 19:12, al-yeti said: Means you probably need to change all the batteries as one by one they will all go , so don't cheap skate it change all Expand Thanks, I’ll change them all Quote
al-yeti Posted February 15, 2021 Posted February 15, 2021 On 15/02/2021 at 20:01, SteveC1458 said: Thanks, I’ll change them all Expand Battery pack inside panel probably needs doing to , you have to open panel let it hang from a few wires and hope for the best , it's not best of designs Quote
Amps Posted February 16, 2021 Posted February 16, 2021 Every two years is fine although I guess it can depend on the environment and signal strength. I've known the detector batteries last +4 years but the external siren batteries never make it past 3 years. Quote
MB63 Posted March 13, 2023 Posted March 13, 2023 On 15/02/2021 at 20:16, al-yeti said: Battery pack inside panel probably needs doing to , you have to open panel let it hang from a few wires and hope for the best , it's not best of designs Expand Dont talk stupid. there are screws to hang the panel on. You don’t know what you are doing. 1 Quote
norman Posted March 13, 2023 Posted March 13, 2023 On 13/03/2023 at 17:55, MB63 said: Dont talk stupid. there are screws to hang the panel on. You don’t know what you are doing. Expand Cracking first post, welcome to the forum... 1 Quote Nothing is foolproof to a sufficiently talented fool.
