n18lldn18lld Posted February 22, 2021 Author Posted February 22, 2021 20 minutes ago, PeterJames said: He said app, not RF strength, clean your ears out! That puzzled me too. I’ve now been here long enough to understand my ‘upgraded’ alarm is a dinosaur. So what would be regarded by members as a decent system with app access? Quote
Tjeerd Posted February 22, 2021 Posted February 22, 2021 Reusing the RF kit you already have probably means staying with Risco. Looking over the horizon probably mostly known Texecom and Honeywell and bit less known there's Satel which tends to stay way more up to date with current tech. Quote
n18lldn18lld Posted February 22, 2021 Author Posted February 22, 2021 1 hour ago, Tjeerd said: Reusing the RF kit you already have probably means staying with Risco. Looking over the horizon probably mostly known Texecom and Honeywell and bit less known there's Satel which tends to stay way more up to date with current tech. Yes mate that’s what I did. Probably laid out £150 to get back 100% again. Thought it was ok instead of £400-£500? Know jack **** about intruder but spent 30 years doing fire alarms so I’m just ahead on that front Quote
al-yeti Posted February 22, 2021 Posted February 22, 2021 2 hours ago, Tjeerd said: Reusing the RF kit you already have probably means staying with Risco. Looking over the horizon probably mostly known Texecom and Honeywell and bit less known there's Satel which tends to stay way more up to date with current tech. Forget Honeywell they miles behind most for rf Quote
