Posted (edited)
Hi , I am after a bit of advise I have recently installed a wireless pyronix enforcer at home however I would like to wire in the light up a delta bell X external module. It came with a battery powered wireless external sounder however i would prefer not to use this as I have run the necessary wires from
sounder to panel I just need a bit of friendly advice on the best approach to wire it up correctly.
Edited by Elysia
Info
As jw said do you have bell board or a WiFi board , I think you can't have both
Other than that it's in the instructions , and make sure the bell is in scb mode
Posted (edited)
It’s in the installation manual. Board comes with the panel.
program circuit 33 as tamper.
Edited by Amps
