Guest thirteeneast Posted September 2, 2003 Posted September 2, 2003 would anyone know conections between 9448 and texecom bell box ... all im getting is a tamper fault when connected?. now ive bridged tamper loop on panel and all is ok, so what should the connections be ....? also zone chimes dont seem to work?.. any ideas. ???...
JB_ Posted September 2, 2003 Posted September 2, 2003 Bell Box Panel A ---> 12V B ---> Bell C ---> TR D ---> 0V S ---> STR Depending on what texecom bell box it is, i think the LED's on the bottom of it tell you if there's a tamper on the box. Left LED flashing battery connected. Right LED flashing tamper closed. Both LED's flashing tamper closed and hold off from panel present. Dont quote me on that, it's from memory and we only ever use the Odyssey 3, but it does say in the papers you get with the bell itself.
Guest thirteeneast Posted September 2, 2003 Posted September 2, 2003 no led's at all??? its a odyssey 3e... thanks for the reply...
Guest dale Posted September 3, 2003 Posted September 3, 2003 It sounds like you have a problem with the 12v supply as provided that there is 12v supply the LED's should light up. Have you moved the +ve battery terminal from the null terminal to the +12v batt terminal? This should at least make the left LED start to flash (as I recall).
JB_ Posted September 3, 2003 Posted September 3, 2003 Yeah as dale said when you look at the terminal connections inside the 1st 3 are where the internal bellbox battery connects to, the red wire comes parked in the middle(nc) terminal and needs moving the the right 1 spot, this starts the left led flashing, then when u put the front cover on and the tamper closes the right led flashes on its own. Check if you have a multimeter set to DC volts that there's 12 volts across 12v and 0v at all times, and not across the 12v and Bell terminals. When you say the sounder works, at which stage does it start to sound?
Guest mac shah Posted April 18, 2006 Posted April 18, 2006 Hi Would anyone know how to wire up a flashguard xpro bell as SAB on a Scantronics 9448UK-60 panel. :'( Thanks
willman Posted April 19, 2006 Posted April 19, 2006 HiWould anyone know how to wire up a flashguard xpro bell as SAB on a Scantronics 9448UK-60 panel. :'( Thanks What connetions do you have on the bell? and i would be hppy to help Will Trade Member
Guest mac shah Posted April 19, 2006 Posted April 19, 2006 Hi Will Thanks for the quick response. These are the connections on the bell: 1)TRIG +VE 2)TRIG -VE 3)SUPPLY +VE 4)SUPPLY -VE 5)STROBE +VE 6)STROBE -VE 7)TAMPER SERIES 8)TAMPER RETURN 9)MICROSWITCH 10)MICROSWITCH I have been able to get a connection document. PLEASE DO NOT POST LINKS TO ENGINEER DOCUMENTS I should be able to work it out BUT your comments will be helpful. Thanks again.
