Keef Posted March 7, 2021 Posted March 7, 2021 I want to add this contact to my garage door but I am not 100% sure about the wiring It has, 2 white wires - reed switch 2 red wires - tamper I know how to wire the white wires via EOL, but do I need to use the tamper wires as well, or is it not necessary ? I was thinking 1k across the white wires Zone common in to white wire other white wire to red other red to zone return with 1k Thanks for reading, hope it makes sense Quote
MrHappy Posted March 7, 2021 Posted March 7, 2021 (edited) Edited March 7, 2021 by MrHappy Quote Mr Veritas God
al-yeti Posted March 7, 2021 Posted March 7, 2021 39 minutes ago, Keef said: I want to add this contact to my garage door but I am not 100% sure about the wiring It has, 2 white wires - reed switch 2 red wires - tamper I know how to wire the white wires via EOL, but do I need to use the tamper wires as well, or is it not necessary ? I was thinking 1k across the white wires Zone common in to white wire other white wire to red other red to zone return with 1k Thanks for reading, hope it makes sense So you need the tamper proof box and the grommet should fit on it aswell and do as Mr H says or he send the boys round Quote
Keef Posted March 7, 2021 Author Posted March 7, 2021 Thank you MrHappy, thats how I thought Just so I have this right in my head. If I only used the white wires and someone cut the metal cable, it would cause a open circuit. Using the red as well, it will cause a tamper ? Keef Quote
Keef Posted March 7, 2021 Author Posted March 7, 2021 3 minutes ago, al-yeti said: So you need the tamper proof box and the grommet should fit on it aswell and do as Mr H says or he send the boys round Yes sir ;-) Quote
MrHappy Posted March 7, 2021 Posted March 7, 2021 cutting the sleeve when the system is unset, will do nowt cutting the sleeve well the system is armed will produce an alarm Quote Mr Veritas God
sixwheeledbeast Posted March 7, 2021 Posted March 7, 2021 Short answer is yes. Bear in mind Mr H's helpful diagram doesn't include the JB tamper which would go in series, much like the red pair does. Something like a J81 or I prefer JB707 would be suitable for connections. Quote
MrHappy Posted March 8, 2021 Posted March 8, 2021 I toyed with drawing it with a JB727 Quote Mr Veritas God
Keef Posted March 8, 2021 Author Posted March 8, 2021 Thanks for all the help, but I don’t think even you lot could solve this !!! I had this great idea to bury the cable going to the garage while I was doing the footing for a patio. Buried it under 6 inches of hardcore and concrete, then paved the whole thing. Just gone to connect the wires and found out I have used phone cable by mistake, knew I should have use conduit Quote
MrHappy Posted March 8, 2021 Posted March 8, 2021 26 minutes ago, Keef said: Just gone to connect the wires and found out I have used phone cable by mistake, knew I should have use conduit sorted.... Quote Mr Veritas God
