Hi, does anyone know if the BT VP1000 frequency is 868-0 or 868-1
Also, can the Magnetic door contacts Aux terminals be used the same as the MCT-302 as they came with a jumper between the terminals for when it wasn't being used but the VP1000 magnetic contacts didn't.
Thanks
As far as I was aware they are just a standard early model BT branded Powermax, this was before ADT had there own frequency as they where probably still using Admeco at the time?
Never seen inside a BT branded contact so no idea what is different but there is a DIP switch for the terminals on a MCT302 as well as the link.
To be honest it's not worth spending money on it, Powermax stuff is one way and cheap, really should be looking to upgrade to a two way system if you need to alter the system.
ok thanks for the reply
