3 hours ago, Ynotmi said:
OK thanks, you've lost me now. Maybe a future project.  Thank you anyway ?
Well it does say coming soon dude
Surely that's clear enough.....
I now have a couple of TCC8M fobs that work with the system, but I have a configuration issue on my Galaxy Flex20.
I'd like to set the fobs up, so that they can be used to set and unset the system, but not be able to unset during an alarm condition.
The idea behind this, is so that if the alarm is sounding, the only way to unset it would be to enter a valid user code in the keypad (e.g. so if an intruder found the fobs in the house, they would not be able to cancel the alarm).
I've tried all the various options, but can't seem to get the system to do this.
The nearest I have got to is to assign the alarm fobs to their own unique users with level 1 access. But this results in being able to set the system with the fobs, but not being able to unset the system, even if the alarm has not been triggered.
Any ideas on how I can prevent the fobs from being used to cancel a sounding alarm?
Thanks ?
Thanks ?
In user options does it not give you those user options  set / unset and another can't remember what it was tho
Or am I thinking dimension maybe ....
The only thing in user options that comes near is the user level, but this only appears to affect the abililty to reset the system (rather than cancel the alarm).  If I set the RF fob user to level 1, then the fob can be used to set the system, but not unset it... I want to use the fob to unset the system, but not if the system is in an alarm state.
2 hours ago, james.wilson said:
the only panel i know of that does that is the hkc. Can you link the user number to prevent use?
Good idea using Links, but it doesn't appear to work. If I link the user, then that user's code cannot be used to cancel the alarm using the keypad, but the keyfob (which is only assigned to that user) still operates.
So frustratingly, Links don't seem to do it ?
