Posted (edited)
Hi,
I'm currently replacing a Honeywell alarm system with the Premier Elite 24. I have completed the installation and everything is working as it should apart from the two wired door contacts which are showing tamper alerts.
Can anyone offer any advice on how to resolve this issue? The current wiring only uses two cores in the contact and then the appropriate panel zone.
Thanks in advance for any advice!
Edited by Macca80
26 minutes ago, Macca80 said:
Hi,
Perhaps give model
PIR model number assuming you had built in resistors
And door contact model? Assuming no resistor ?
Probably if you required the door contacts probably do e them wrong or wrong resistance
What previous Honeywell system was it
1 minute ago, al-yeti said:
Perhaps give model
Hi,
Yes there's no resistors in the existing door contacts so from what I've read that's the issue.
The old alarm was an Accenta S Mini
Can you recommend any contacts with inbuilt resistors?
Thanks.
Just now, Macca80 said:
Hi,
Thanks.
Was there a resistor pack in the texe?
2 minutes ago, Macca80 said:
No there wasn't
Ok perhaps one of the others can answer which contact you should get ,I am not familiar with resistor choices on the texe
Assume you got pirs with selectable resistors , what have you set them to currently , for alarm and tamper?
OK thanks. My PIRs have selectable resistors set to 4k7 and 2k2. I've tested the system today everything's working fine apart from the door contacts. I did plenty of reading up, but I didn't realise I'd need contacts with resistors for EOL wiring.
You need resistors for your contacts or contacts with resistors built in would be best.
Something like SC570/WH/MULTI for example.
They don't provide resistors in any Texe stuff now.
  • Thanks 1
There you swb to the rescue you model number to purchase
  • Thanks 1
