On 26/03/2021 at 10:59, Alexander02 said:
Hi,
Have Texecom fixed their issue with the backlights failing in their Odyssey X external sounders. I've heard people say that they have and people say they haven't and I've seen a few with failed backlights and some that have been installed for around a year that still have functioning backlights.
Thanks,
Alex
Overall I think the bell is not that good , get something else
Posted (edited)
10 hours ago, james.wilson said:
Al what do you use?
Only use the hkc bells now , have to have specific reason not to .....
Edited by al-yeti
3 hours ago, sixwheeledbeast said:
I actually would say they are well designed even tho I don't use that model.
Anything with a backlight will die eventually and at least the led strip is removable/replaceable.
Yes compared to the old delta on board led , but then the other delta had the module aswell, and that led module used to be available a fair bit , didn't see much fail on latter
