I have a inherited a security installation.  The main board is U/S.
I was planning to dismember the system and replace the controller with say a Honeywell Galaxy system.  There is already a board like that elsewhere in the building.
I would like to find out a little bit about the unit and the wiring before I take it out.  It appears to be an ancient Thorn security system. Photo attached.
Some sensors are new, some are ancient.
The board appears to use 6 wires per device/circuit, with 2 for power and ground, so I guess 2 for detector (CCTx) and 2 for the anti-tamper (A/Tx).
I have not yet taken a sensor to bits, so I have no idea what is in it.
I know the colours mean nothing.  In this install Blue/Yellow appears to be power and ground,
So I guess are red and white zone (CCT)  and green and black anti-tamper (A/T).
Is this likely?
How the blazes do I wire those sensors up to a more modern board like a Galaxy that seems to have only 2 wires per zone/area.
Any input appreciated.
Posted (edited)
Expand
4 pirs, 1 door contact, 1 keypad, 1 speaker ,1 external sounder.
to renew everything is at most a days work & I've allowed extra as its a secret nuclear bunker ?
being big head.... I'd expect you'll spend the week end at it ?
Edited by MrHappy
Expand
You can set the Galaxy zones to N/C like your old system. Each zone can be programmed individually on Dimension and Flex.  I would recommend reconfiguring with new sensors or the addition of resistors (I've never had a problem adding 2x 1k resistors in existing sensors for double balanced zones).
It may be worthwhile changing the PIR's anyway, as they're very cheap and the pyroelectric element in the sensors do deteriorate over time reducing their sensitivity.
Mr Happy: Close, Nae keypad - somebody stole it!  But since the place is secret I have lost it and need an extra day to hunt and find it.  I suspect a happy week at and hour here and there will do - assuming the existing wiring still forms a circuit.
GalaxyGuy: Thanks for the comment on Dimension and Flex.  The kit is V old and as you say new PIRs are not expensive.   I was more interested in the use of the three circuits (power,zone and tamper) rather than the 1-2 they use now.
Expand
With zones set to NC, you then consume two zones to cover zone and tamper circuits. This is a bit of a waste of zones when you can cover the tamper open/short circuits with the addition of resistors.
Expand
the controls date back to 1989 ish
Expand
Tunstall where doing 4k7/2k2 EOL back in the late 80's
What you have a the moment is positive loop for alarm, a negtive loop for tamper & +/- to power a pir
then you can bodgengineer eol resistors on at the panel end to hang the old sensors onto the new controls, until your ready to replace
but its always prudent to spend 5 mins & measure the wiring before starting to rive the controls off the wall
Expand
agreed; the date of 27th Feb 1991 appears on the THORN install quote - with an all-in price of £1015;  Maint was £100 p.a. fixed price for 3 years.  What you find in old documents....
