Analogue addressable panels
housty
Hi all
Could some one try and explain to me what is involved in installing analogue addressable panels? we are fairly competent in conventional fire panels and are thinking on using addressable in the larger installs.
Also do i need to use the company which makes the panel to commission and program it.
housty
Houston Security Systems Ltd
Intruder alarms
CCTV
Door entry
Fire protection
Networking
SSAIB Approved
Hi all
housty
33341[/snapback]
We design sell and commission such system to electrical contractors. The labour saving is £££ . We benefit from the ongoing maintenance revenue as the level 3 access can only easily be done by engineer software.
Jef
Customers!
On a larger job it can sometimes be better to go supply and commission or certainly as you venture into addressable panels as you get the suppliers backup and support.
