Dinko Tsvetkov Posted April 26, 2021 Posted April 26, 2021 (edited) Hi everyone , to be honest I dont work in UK but I have sign in this forum , because in my country(Bulgaria) companies mainly use -2 brands - Paradox and Teletek, however now I am looking for some recomendations for outdoor sensors( the same will be use on teracce of the last floor apartment in city building).Do you know is this model of pyronix TMD15 (Pir/MW) could be used outdoor?Otherwise I probably will use Paradox Dg85, but he is only pir and in the hot summers( >40°C) it doesnt work so well. Edited April 26, 2021 by Dinko Tsvetkov Quote
sixwheeledbeast Posted April 26, 2021 Posted April 26, 2021 TMD's are not for outdoor use no. Wouldn't say they are suitable for anything more than very light commercial (clean office) as they are terrible for false alarms from past experience of them. For outdoor the sensor should be designed for the environment, over here I would consider something like an Optex LX-402 for that type of detection, no idea if you can get that type of thing in Sofia. If your Paradox sensors are for outdoor maybe you have a positioning issue? Even the best sensor you can buy will struggle from positioning into direct sunlight. Quote
Dinko Tsvetkov Posted April 26, 2021 Author Posted April 26, 2021 On 26/04/2021 at 08:37, sixwheeledbeast said: TMD's are not for outdoor use no. Wouldn't say they are suitable for anything more than very light commercial (clean office) as they are terrible for false alarms from past experience of them. For outdoor the sensor should be designed for the environment, over here I would consider something like an Optex LX-402 for that type of detection, no idea if you can get that type of thing in Sofia. If your Paradox sensors are for outdoor maybe you have a positioning issue? Even the best sensor you can buy will struggle from positioning into direct sunlight. Expand Quote
Dinko Tsvetkov Posted April 26, 2021 Author Posted April 26, 2021 Thank you very much for fast and valuable opinion, however I didnt mention that 3 of the detectors will be under wide penthouse which dont allow detectors to be hit with direct sunlight.I will see is there any distributor of Optex in Sofia/Plovdiv.I have thought also for GJD300 even their much more expensive than Paradox it is not a problem for this client , but I suppose that she won't like how they look like:)). She keep to look nice too. Quote
sixwheeledbeast Posted April 26, 2021 Posted April 26, 2021 I wouldn't consider GJD sensors for an intruder alarm they are more for CCTV and lighting controls. Maybe consider other detection options like active IR beams these shouldn't have sunlight issues (Optex and Takex brands would be popular quality options here). Quote
james.wilson Posted April 26, 2021 Posted April 26, 2021 I have used the takex pir externally with success not for alarms as such but for alerts At home I also use takex external 12m pet tolerant pir ms-12te Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
Imnotshankled Posted April 28, 2021 Posted April 28, 2021 On 26/04/2021 at 08:04, Dinko Tsvetkov said: Hi everyone , to be honest I dont work in UK but I have sign in this forum , because in my country(Bulgaria) companies mainly use -2 brands - Paradox and Teletek, however now I am looking for some recomendations for outdoor sensors( the same will be use on teracce of the last floor apartment in city building).Do you know is this model of pyronix TMD15 (Pir/MW) could be used outdoor?Otherwise I probably will use Paradox Dg85, but he is only pir and in the hot summers( >40°C) it doesnt work so well. Expand Its the pyronix XDL12TT Quote
