I have a partitioned system and I want to add an internal sounder to one of the partitions. I know that I can connect it into the same terminals as the external sounder but I only want to have it activated in a specific partition. I can configure it in the Wired Outputs as a siren but I'm unsure of the PCB connections.
I want to use a Kinetic Quad Piezo Sound Bomb Internal Sounder KSB2
Can anyone help me? I've attached a diagram of the PCB layout if this helps.
Thanks.
Use the out puts and progg to follow partition not sure how much current your sound one draws possible use smart relay just in case
www.AllanMoncrieffAlarms.com
