I have pile of WD Green Power HDD, pulled from some vista DVR's
popping them into a windows machine, a handful are recognized with "disk management" but most ain't
WD drive utilities does not recognise on of the working drives-
However a Hik NVR will recognise the drive(s) & store data on it ?
odd...
odd...
Try MBR tool , maybe that's the issue
55 minutes ago, sixwheeledbeast said:
What do you want to do with them?
just sorting out the swag pile,
I wanted a 2nd hdd for works cctv's & got carried away & now have more than a dozen
I have some used PSU's but not the correct one to repair a wbox branded hik nvr (£58 for a psu) so binned it & held onto the toshiba 2tb
I've wheelie bin full of dvr cases & knacked speed domes,
I'm also hoping I've case fan which is suitable for a HP switch as mine is quite LOUD
