HELP Optima G3 beeps every 5 minutes
Guest Adam Burgess
Its not your alarm get the back of those draws out !
33513[/snapback]
LOL at PETER :lol: everyones waiting with baited breath now PMSL :w00t:
Guest Adam Burgess
33513[/snapback]
Deffo NOT smoke alarm !!! :(
ADAM - is the noise deffo coming from the panel???????
Smoke detectors.
Or it could be anything, check the back of drawers, under wardrobes, behind the telly. It's not the alarm, that's for sure.
Is a zone light lit on the 1-8 display of LED's - it may be as peter suggested a while back that chime is on one of the zones??
Anyway as I said is the bleep DEFFO from the panel???????????
Adam - how did you check the batteries in your smokes anyway?
On the Optima panels the Tamper light flashes if the service timer is on :yes:
Do you have a Carbon Monoxide detector?
33521[/snapback]
.........PLUS- I would take the batts out for 10 minutes and see anyway - DONT FORGET TO PUT THEM BACK IN THOUGH!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
33520[/snapback]
DNS - does the chime still work on an Accenta when it's part set?
