Confusedman Posted June 8, 2021 Posted June 8, 2021 Just finished installing the alarm at my mums house. Fitted a Honeywell accenta mini gen4 with 2 lcd keypads, 2 odyssey X3 bellboxes, 4 honeywell PIRs and a couple of Veritas E sensors All is great apart from just one sensor Its a texecom impaq SC door contact and shock sensor. It works on the magnetic door contact and also the tamper but it just won't trigger on impact?? The LED indicated the impact, I can program the sensitivity no problem as well I've set the EOL resistance to 1k for both microswitches as recommended in the info sheet What am I missing? Can anyone help please Thank you Quote
MrHappy Posted June 8, 2021 Posted June 8, 2021 39 minutes ago, Confusedman said: I've set the EOL resistance to 1k for both microswitches as recommended in the info sheet What am I missing? its a double poled panel... Quote Mr Veritas God
al-yeti Posted June 8, 2021 Posted June 8, 2021 6 hours ago, Confusedman said: Just finished installing the alarm at my mums house. Fitted a Honeywell accenta mini gen4 with 2 lcd keypads, 2 odyssey X3 bellboxes, 4 honeywell PIRs and a couple of Veritas E sensors All is great apart from just one sensor Its a texecom impaq SC door contact and shock sensor. It works on the magnetic door contact and also the tamper but it just won't trigger on impact?? The LED indicated the impact, I can program the sensitivity no problem as well I've set the EOL resistance to 1k for both microswitches as recommended in the info sheet What am I missing? Can anyone help please Thank you So basically no eol required put them in a nonnuse position Quote
