sixwheeledbeast Posted June 17, 2021 Posted June 17, 2021 A dodgy or misconfigured anything on the network "could" cause it. Have to try and isolate to narrow it down somehow. You should be able to calculate what bandwidth should be on each link if you add up all the equipment. I guess these are unmanaged switches so you can't look at logs or change any QoS/Bandwidth settings etc. Quote
al-yeti Posted June 17, 2021 Author Posted June 17, 2021 9 minutes ago, sixwheeledbeast said: A dodgy or misconfigured anything on the network "could" cause it. Have to try and isolate to narrow it down somehow. You should be able to calculate what bandwidth should be on each link if you add up all the equipment. I guess these are unmanaged switches so you can't look at logs or change any QoS/Bandwidth settings etc. Correct all unmanaged But I get what your all saying , thanks for the guidance will look into it Quote
