Toleman Posted June 23, 2021 Posted June 23, 2021 Hi people, I’m wondering if you can answer some questions for me. I’ve fitted an I-on 40 hybrid system on my house and initially fitted an internal sounder to LS +/-. Problem is the entry and exit tones are deafening so I want it to just make a racket on full alarm. Should I connect it in parallel with the external bell or shout I use one of the numbered outputs? If so how do I go about this? Bell & -trigger on the bell box outputs (1bell box used) op1 and Nc on the Outputs but not sure how these are programmed out the box? thanks in advance, Chris Quote
sixwheeledbeast Posted June 23, 2021 Posted June 23, 2021 (edited) Speaker outputs usually have a volume control and that volume control is only for the tones and chime not alarm. Depending on the controls it maybe programmable in the settings or a potentiometer on the PCB, I don't know the I-on but it will be somewhere. Edited June 23, 2021 by sixwheeledbeast typo Quote
