lmor1 Posted June 30, 2021 Posted June 30, 2021 (edited) Hi, I was wondering if anyone knew what the installer code was for a vistronic Powermax complete system? I am trying to add a keypad to my system but the code I have seen in the manual #### does not work Edited June 30, 2021 by sixwheeledbeast No codes Quote
aissecur Posted June 30, 2021 Posted June 30, 2021 (edited) If it’s non uk it may be #### can you not default it & reprogram from scratch ? Edited June 30, 2021 by sixwheeledbeast No codes please Quote
aissecur Posted June 30, 2021 Posted June 30, 2021 If you are not an installer, then the installing company will of changed the engineer code if that is the case then I would suggest getting a installation company out to default and add the keypad for you Quote
sixwheeledbeast Posted June 30, 2021 Posted June 30, 2021 We don't provide defaulting information, codes or engineering manuals here as per our guidelines. We have no way of verifying you are not trying to tamper with a system that is not your own. Installers use their own codes they wouldn't leave them default as that could be exploited. If the system is maintained you should contact your installer, if not follow the manual you have to start fresh. However, you will need knowledge of how to program everything back or it will not function properly. Quote
