Posted (edited)
Hi,
I would like to know how you guys do the maintenance of your Radio devices.
I have a GalaxyFlex 020 connected to Honeywell D08M (wireless door detector) and Honeywell SHK8H (wireless shock detector on some windows)
- According to Honeywell commercial documentation the battery (Lithium 3V CR123A) can last nearly 5 years
- Normally we are supposed to get a notification on the keyboard when the voltage falls between 2.5V and 2.7V
  • Based on this, what are your best practices ?
      - if you were me, how often would you change the batteries ?
      - which brand would you use ?
  • In addition, do you know if there is a menu where we can see the battery level of the RF devices ??
      - not sure, but I believe I should see something in 61.3 Warnings, when the battery is low.
      - Otherwise, could we check this in real time when the battery life is still ok ?
  • Do you now what Supervision RF means ?
      - From my understanding the RF devices talk with the control panel every x minutes.
         Is this the supervision RF ?
         or is Supervision RF an other more advanced check (battery status, strength of the signal, ect )
Thanks in advance for your help on this,
CJGD
Edited by CJGD
I change all batteries every 2 years.
Panasonic or duracell
meaningless see attached graph showing discharge curve. They run then once they start to drop are dead within 1 - 2 weeks
see above
Yes, as you say the device should poll every x seconds or minutes (depends on brand) some stuff can be hours!
Once it hasnt recieved them over period x then the panel reports supervision failure
  • Upvote 2
  • 2 weeks later...
